TwinTurbo.NET: Nissan 300ZX forum - You might check the idle pulley too. It can as well cause th
Subject You might check the idle pulley too. It can as well cause th
Posted by SilverSlickTopTT on March 09, 2010 at 10:45 PM
  This message has been viewed 81 times.
In Reply To Alternator Belt/Pulley issues posted by pocheeyo on March 09, 2010 at 12:55 PM
Message The belt to come off. Check ur voltage on batt when car is on then turn
on heater (big elec load) see if ur volts drop then come back up. That will
eliminate the alt being the a$$hole. Next, If ur worried bout pulley lining
up cut a piece of string 2ft long and place one end on the inside rib of alt
pulley and the other end on the inside of the ur pulley rib where belt is
supposed to go. It should be a straight shot if ur string is at an angle ...
That sucks. Hope it works out
